pop login
- Posted by Robin (6) Offline
I have downloaded your pop login module but I cant get it to work. When I click on the login tab the login window pops up but it wont let me fill it in. When i try to fill it in it closes. What do i need to do to fix it?
Best regards,
Robin Richmond
13 years 1 month ago #1
by Robin
Best regards,
Robin Richmond
can you make a change in your template layout.css on this part
and see if that helps
13 years 1 month ago #2
#tmp-container {
z-index: 0; /* change this to let's say 99999 */
}and see if that helps
Hmmm, is there any way i can make it that you can't register only login? I'm using it for a members area of a club site and i don't want randoms to be able to access this area.
13 years 1 month ago #3
by Robin
So sorry but I'm still not clear on this...is there any way i can make it that you can't register only login?
ah, don't worry about the last question i've sorted it.
I have another though; is there a way of having my club logo on the pop up window instead of the image of a silhouette of a persons head?
13 years 1 month ago #5
by Robin
another thing, where you enter your username and password overlaps with the words username and password, how do i stretch the login box out so that they do not do this?
13 years 1 month ago #6
by Robin
