Responsive Banner Slider 2.2.3
1. Parameters for Sequence Slider type, if you choose it in the Basic Options tab
Auto Play do not work
2. if you click navigation left arrow - no banner will be shown
12 years 11 months ago #1 by korrektkreativ
First of could you replace this file on your live site
/modules/mod_responsivebannerslider/tmpl/default.php
using the one attached? (please unzip it first)
Let us know if that make any difference.
12 years 11 months ago #2 by erwinschro
hi!
at first, auto play works now but only 1 time
and if you press left arrow on navigation you see no banner ??
thx 4 quick support!!
12 years 11 months ago #3 by korrektkreativ
any fix around now??
thx
12 years 11 months ago #4 by korrektkreativ
why you cant fix this issue???
12 years 11 months ago #5 by korrektkreativ
Apologize us...we've been trying with it but no clue...
can you please test it for us using Joomla default template and let us know the result there. If that's work, then we suspect there's a conflict with a module or plugin or your template. Test it with your template again but now please un-publish anotehr modules that using javascript one at a time and see if the responsivebanner works correctly...so we know which module that cause conflict with it.
12 years 11 months ago #6 by erwinschro
