Responsive Banner Slider
Dear Sirs
Please I bought this module but in reality leaves much to be desired The module is properly installed The website is sistemasysistemas.com relationship there banners change as a function of window size, the adaptive responsive not work To test was created two two banners with your category and assigned customers are the type customized.
The code is as follows:
<object style="width: 930px; height: 418px;" width="930" height="418" data="images/flash/serviciotecnico.swf" type="application/x-shockwave-flash">
<param name="src" value="images/flash/serviciotecnico.swf" />
</object>
I can not even see the second banner that has the same content as the first
Please I need to know if this module works or not, tabajo with Jommla 3.1.5
13 years 2 months ago #1 by Segundo
Can you try with banner images rather than flash images first?
13 years 2 months ago #2 by erwinschro
I have dealt with banner images and the result is the same does not work the adaptive, can not see the image below.
It is the design of the template, as other free modules work but they do not handle custom banners
13 years 2 months ago #3 by Segundo
I have to unpublish the jqueryeasy plugin to make it works. Please have a look now.
13 years 2 months ago #4 by erwinschro
Gracias,
Al intentar trabajar con banners personalizados para presentar archivos .swf, presenta solo al cargar la pagina la animacion del archivo swf. Luego hace la transicion de archivo pero sin animacion del archivo swf lo puede verificar en la pagina
el codigo personalizado para presentar en el banner el swf es el siguiente:
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
codebase="download.macromedia.com/pub/shockwave/ca....cab#version=6,0,0,0"
width="930" height="418" id="encabezado" align="">
<param name=movie value="www.sistemasysistemas.com/images/flash/serviciotecnico.swf">
<embed src="www.sistemasysistemas.com/images/flash/serviciotecnico.swf" quality=high width="930" height="418" name="encabezado" align=""
type="application/x-shockwave-flash" pluginspage="www.macromedia.com/go/getflashplayer">
</embed></object>
Le ruego me ayude con este requerimiento, en la pagina demo del modulo lo hace normalmente
13 years 2 months ago #5 by Segundo
So sorry mate we don't understand it ( Spanish? )... :)
13 years 2 months ago #6 by erwinschro
