mini k2 1.2.2
hi!
Thumb pics are not displayed!!
it seems that they are behind the k2 article ?
thx 4 help
13 years 2 months ago #1 by korrektkreativ
How do you manage to insert images on that K2 Items?
it looks to me they are not behind the mini k2 content but it's like you don't have any K2 item image uploaded there. What I can see are image gallery on the 1st item and Mini K2 can't generate thumbs from the Gallery I'm afraid and no images on remaining 3 K2 Items when visiting their item page.
The weird thing is I can see those 4 thumbs at first page load for a second then they dissapear...even in your html sources...i can't see them...
13 years 2 months ago #2 by erwinschro
hi!
thumbs are uploaded as you can see at first load for a second!!
they are also in html sources
<div class="thumbs">
<a href="/neu-vorfuehrwagen/alfa-romeo/item/2-alfa-giulietta">
<img src="/media/k2/items/cache/e0a70f72bdae9885bfc32d7cd19a26a1_S.jpg" alt="Alfa Giulietta" class="box-img" /></a></div>
you can also see the thumbs when you enter the category not in the article
13 years 2 months ago #3 by korrektkreativ
Yeah...something cause this...it might be from a template or any plugin you've used there
if you view your html source file after the first second what you can see is something like this
<a href="/zweiraeder/vespa/item/24-946">
<img class="box-img" alt="946" src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///ywAAAAAAQABAAACAUwAOw==">
</a>
</div>
I don;t know where that data:image come from...that's not normal for minik2...
PS. you also dont need to write double !! on your sentence as that's makes me thing you're mad at us or something you don't like...this module is a free stuff anyway.
13 years 2 months ago #4 by erwinschro
ive found the problem!!! bug in masonry !!!
the solution update jquery.masonry.min.js and now it works
cheers
13 years 2 months ago #5 by korrektkreativ
