Problem with css in xtypo
- Posted by Guillermo (2) Offline
I have created a Xtypo in Custom HTML module, inserting codes manually using "HTML Source Editor" and this work fine when show a article, you can see "Horari"
iz.gsmoral.com/locales/sabadell.html on right hand
but when charge a module (like BreezingForms or FhocaMenu) the css to Xtypo don't work:
iz.gsmoral.com/locales/sabadell/carta.html
iz.gsmoral.com/corners/matadepera/caracteristiques.html
13 years 2 months ago #1
by Guillermo
Yes that's how it works I'm afraid...as this is a content plugin so it only works if your page is standart core content component.
13 years 2 months ago #2
Thanks for your response.
I add the css class in my css template and work fine.
13 years 2 months ago #3
by Guillermo
- Posted by John Coupland (5) Offline
Hi Guys, can you explain how you did this, I'm having problems with a custom template, the buttons don't show and the warning symbols appear out of the article. I guess it is a css override problem
13 years 2 months ago #5
by John Coupland
Hello CornishCharlie
first of can you create a new thread for this? I'm afraid we can be annoying for the thread starter if we continue here.
thanks
13 years 2 months ago #6
thanks
