image split in two
- Posted by matthew (104) Offline
Is it possible to have only one image either the top image which is in the image tab in k2 edit item or the actual k2 item which is the below image
To take up the hole black portion of the k2 deals because I need the black section to display an A4 brochure see attached
13 years 2 months ago #1
by matthew
How did you manage to have the 2nd image at below part? can you just remove it?
13 years 2 months ago #2
Yes I can remove it. Its the actual k2 item that you can edit in the wizzywig editor can I change it to only display an A4 brochure instead of the image tab being ontop or can I have just the image tab displayed either way see attached?
13 years 2 months ago #3
by matthew
I don't understand why you don't want to remove the inserted image in wysiwyg Editor? that way you will only get one image from the Image Tab, right?
13 years 2 months ago #4
If i do that I get see attached
Thats why I want to resize the black area to an A4 page so the tour operators can use there A4 brochure. Can I make a hack to size the k2deals area to A4?
Better still
It would be better if the top image came from the wysiwyg editor and had full control of the black space that was set to A4 page and if you put more than an A4 page the read more button would appear because the template would have more power is that possible?
Can it be hacked to use the wysiwyg editor instead of the image tab?
Because in minik2 nothing displays without an image in the image tab so really minik2 is useless without an image.
Can it be hacked to use the wysiwyg editor instead if the image tab?
13 years 2 months ago #5
by matthew
Better still
All hacks yes they can be done for sure. But so sorry but it's not that easy and we can't help you with those hacks because that's beyond our support can provide. It needs lot of custom works to get done.
13 years 2 months ago #6
