fonticons problem
- Posted by korrektkreativ (18) Offline
Hi!
fonticons is not loaded if no content module is loaded.
we use k2 as content manager and if there is no joomla content - fonticon will not loaded for other modules.
on startpage everything works fine:
www.meisinger.at/
and on this side the fonticons will not loaded in modules:
www.meisinger.at/neu-vorfuehrwagen-m/alfa-romeo
do you have a solution for this problem?
thx
13 years 2 months ago #1
by korrektkreativ
www.meisinger.at/
thx
Not sure why the fonticons css is not loaded on this page only
but it's loaded on this page
www.meisinger.at/neu-vorfuehrwagen/alfa-romeo
as you can see on the twitter and facebook icons at the bottom part.
what type of menu item this page is? is it still K2 component?
what's the different between neu-vorfuehrwagen-m and neu-vorfuehrwagen on their urls? are they different K2 categories or?
13 years 2 months ago #2
