Jquerry crash
I am using Joomla 3.1.1 and the JSN Mico free Template from JoomlaShine. I installed the Carousel Banner extention but it has a problem with some other extentions I am using such as JLV Facebook Sidebar or Spotlight module, the problem is that the carousel banner will not load at all when the other extentions are enabled. I let Carousel enabled and unpublished/disabled the rest of the extentions and it works fine. Are there any solutions / suggestions to this problem?
Ty for your time.
13 years 2 months ago #1 by thomas
we're unable to give a solution until we see it in a live url...
13 years 2 months ago #2 by erwinschro
Agree, i apologize you.
13 years 2 months ago #3 by thomas
and where do you publish the carousel banner?
13 years 2 months ago #4 by erwinschro
It would normally appear in white framework before the sitemap
13 years 2 months ago #5 by thomas
I see there's a 2nd call to jQuery library at your head section. my guess that could be the cause.
Can you find out from where it's coming and de-activate it
<script src="ajax.googleapis.com/ajax/libs/jquery/1.8.3/jquery.min.js" type="text/javascript">
I guess it's from Videobox plugin?
13 years 2 months ago #6 by erwinschro
