Template width
- Posted by matthew (104) Offline
Is it possible to widen the template by about 1.5cm because I have an iframe that I want to display that its width makes it need scroll bars which I want to avoid to keep the design right?
13 years 1 month ago #1
by matthew
So sorry matt
it's possible but that would need lot of code changes on the template layout codes as we're using a fix width grid system and changing the base width will effect all grid calculation.
13 years 1 month ago #2
it's the same case...as it's width should follows the template grid system Matt. Sorry.
13 years 1 month ago #4
