Moot loader
Hello! =)
so I subscribed to moot, reserved my name, downloaded the plug in, enabled it, did the tag in article and new menu voice but still the system doesn't process the tag, it just write it out on the entry.
To clarify: I get an entry with {moot}cocooners{/moot} instead of the actual forum =)
Using joomla 2.5
Any help'
Thanks,
Ivan
13 years 1 month ago #1 by Tora
Hello Ivan
Can you post a live url so we can take a closer look?
thanks
Hello again,
here's the url:
www.cocooners.it/index.php/forum
Thanks!
Ivan
13 years 1 month ago #3 by Tora
Does your template load jQuery library or not? if not then could you try load jQuery library from the Moot plugin? and see if that helps...
13 years 1 month ago #4 by erwinschro
Honestly? I have no idea :) I just installed joomla + purity2 template so I assumed that everything was in place.
Now about that jQuery library... I'll have a look on google but it's a starting point, thanks :)
13 years 1 month ago #5 by Tora
I am facing the same issue. Already tried to enable JQuery in the plugin configurations, and nothing happens
12 years 4 months ago #6 by Igor
