Flexisel mode not working
  • Posted by Dainius Krusinskas (6) Offline
Tried Carousel Banner, but it doesn't work in flexisel mode. Got msg. "Notice: Undefined variable: img_width in /var/www/vhosts/censio.lt/subdomains/test/httpdocs/modules/mod_carousel_banner/mod_carousel_banner.php on line 48 "
I've set up img width and height
13 years 1 month ago #1 by Dainius Krusinskas
Hello Krusso
Are you able to edit this file
.nbs-flexisel-item img { max-width:$img_width; max-height:$img_height;}
edit it to
.nbs-flexisel-item img { max-width:$width; max-height:$height;}
see if that works and do let us know the result.
I've edited, but no effect. At least I don't see any msg. Previous dissappeared. In default mode it works very strange also: one banner below another, not in a row and veeery huge, despite banner's setting.
13 years 1 month ago #3 by Dainius Krusinskas
If the warning message is gone then the code fixed above is works.
Those other thing is other stories. It looks like a jquery conflict issue.
Do you have another module that also use jQuery or maybe your template load it? it's hard to guess if we can't see it live
13 years 1 month ago #4 by erwinschro
jQuery version loaded from jQuery UI from Google CDN on template is 1.8.3 Is it possible to solve this confict, since every module for slide shows does not work?
13 years 1 month ago #5 by Dainius Krusinskas
Sorry, mistake Loaded jQuery from Google CDN, version 1.8.3
13 years 1 month ago #6 by Dainius Krusinskas
