Save k2 item in front end
Nothing saves in front end at all I thought it was the button being covered but even when you click save nothing saves so k2 users cant save there product in front end can this be fixed? or the template has no use for front end editing?
Could this be a permissions problem? I even set permissions see attached but still no save in frontend?
I thought it was the editors like JCK and JCE but I have tried all editors and none save in frontend
not even admin can save in frontend.
13 years 1 month ago #1 by matthew
You should set permission from the K2 User Groups, create a new user group first if needed then set that user group to allow Front-end item editing.
I have see attached
13 years 1 month ago #3 by matthew
and the result?
13 years 1 month ago #4 by erwinschro
Did not work can not save a k2 article in the front end
When you click save the browser refreshes and stays open in edit mode but all the article is missing it never saves?
Would MijoACL fix the problem?
13 years 1 month ago #5 by matthew
Please see my answer in other thread of yours.
13 years 1 month ago #6 by erwinschro
