using the template on an Iphone or an Android phone
I am testing the dealPlazza template.
Is it possible to have some modules not shown on an Iphone.
I'm thinking for instance to the Peel page module which is not very smart on an Iphone.
thanks for help
best regards
Michel
13 years 11 months ago #1 by rottenberg
Hello rottenberg,
If you mean that the Page Peel module doesn't appear on an Iphone, otherwise, it is shown normally on desktop browsers, I'm sorry that function is not available yet in our module system now. and I still didn't find the way to get as like as that until this time
13 years 11 months ago #2 by ronysyz
Well, it's actually you can do that by using css. The module is actualyy still there but hidden by css.
Please try to add these lines to your tempate.css
@media screen and (max-width: 760px) {
	#page-peel-banner {display:none;}
13 years 11 months ago #3 by andy
thank you
I have also found a plugin (advanced module manager from Nonumber.nl).
this plugin is very usefull : the rules to manage modules are very numerous. I use it since a long time. I have just discovered that you can choose to display the module following the OS. It's not only mobile ou classical. You can give the OS mobile chosen (Android,IOS,Blackbery...).
13 years 11 months ago #4 by rottenberg
