issue with related articles module
Hi Guys
I've installed your module & plugin.
It doesn't work when an article is "featured" (ie placed in the front page). The title of the article disappears and when we follow the normal link, there is a 404 error.
More, in other cases, it's not possible to display an article and the error is :
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 19456 bytes) in /homez.120/upmagazi/www/modules/mod_relateditems_xtd/mod_relateditems_xtd.php on line 28
Could you please help me.
(I use a conservative cache - Files are CHMOD 777)
13 years 1 month ago #1 by Ayache
First off, this module will only be displayed in the article page, it is hidden in the category blog or featured articles layout.
And I don't see the module published in any of the article page right now, correct? and if it's published, what module position you're intend it to be placed on this template (where is an exact position on your template layout? I'm not sure it will works in such a kind of template though)
Hi thanks for your response
The module position is actually "uncat". It is placed in the article page with the code {module[xxx]}
It seems it wortks fine for one article but not when many articles carry the same module.
And when the article is displayed in the category blog/featured articles, it scrashes the title of the article dispalyed in the category blog and makes the fatal error when we try to open the article.
13 years 1 month ago #3 by Ayache
i don't quite understand with
when many articles carry the same module?
Can you point me an example URL for that?
also an example URL for the category/featurd articles where the module crashes the title of the article displayed? Cause the module should be hidden in the category blog/featured article pages.
13 years 1 month ago #4 by erwinschro
example of URL with fatal error (when module & plugin activated) :
www.up-magazine.info/index.php?option=co...catid=113&Itemid=573
13 years 1 month ago #5 by Ayache
mmmmhhh....I'm not sure on this but the module+plugin works fine in a 'standart' template (template with no such a feature like what you're using). The memory error is definetely not comes out from this module+plugin as you can see in the path mentioned in the error
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 261900 bytes) in /homez.120/upmagazi/www/libraries/loader.php on line 366
so I would like to suggest you to ask this issue on your template provider support forum whether this kind of module+plugin is supported by the template or not. Because this is just an ordinary module, similar like Joomla standart related article module (you may want to test to publish standart Joomla related article module on that same page to see if it works or not too.)
13 years 1 month ago #6 by erwinschro
