Problem with Carousel Banner (flexisel Layout)
- Posted by Bruhn (4) Offline
I have installed the carousel banner (flexisel Layout) for Joomla 2.5 in my website (www.sg-fes.de) to show the Sponsor-Logos.
At the end of all logos the banner will stay empty for some time then it will restart later.
Could you help me to fix this problems please.
13 years 1 month ago #1
by Bruhn
Hello...looks like your site got an error at the moment so i can't take a look at it...
13 years 1 month ago #2
Mmm not sure what happen with the carousel banner images behave like that. I suspect your lazy load image plugin affecting this. what if you disable the lazy load plugin first and see if that helps?
13 years 1 month ago #4
I can't find the lazy load plugin in my plugin-list. Is this plugin part of the joomla 2.5 Installation? I've never installed this plugin.
In the attached screenshot you can see the adjustments, that I made in my carousel-banner module. Is there an error?
13 years 1 month ago #5
by Bruhn
The lazy load could be from your template feature if not a plugin....not part of the joomla 2.5 installation nor from this module. And the configuration looks fine to me.
13 years 1 month ago #6
