Mini K2 Content module is not displaying the images properly for me
The Mini K2 Content module is not displaying the images properly for me.
Iit is leaving a gap after the first row of 4, then it displays 2 gaps, then 2 more images, then displays the next row of 4 below that.
Like this:
XXXX
XX
XXXX
XXXX
I want it to be like this:
XXXX
XXXX
XXXX
XXXX
www.ramms.com.au/fodico/#
Could someone please let me know how to make it line up properly?
Thank you
Ann
13 years 1 month ago #1 by anntaj
it moved the X's
On the second row, those two are aligned to the right
13 years 1 month ago #2 by anntaj
It looks like the masonry effect not working properly. I suspect there's a jquery library conflict between the one loaded by the miniK2 with one loaded from the template.
This is tricky to fix as the jquery lib from this module on this page is loaded first than the template have. If you deactivate jquery lib from your template/plugin then it will work but then at the other pages where there's no miniK2 published (where it loads jquery library) and something need a jquery lib to be there (which previosly supplied by the template/plugin) then it won't works.
So it's up to you then...you may try to de activate jquery lib being loaded from your template (or plugin).
13 years 1 month ago #3 by erwinschro
