mini frontpage
  • Posted by Giuseppe Scaramuzzi (2) Offline
hi! i'm new to joomla (i'm using 2.5) and i've successfully installed mini front page into a category page that displays all the articles in blog mode.
i have 12 articles displayed into the page and mini frontpage works fine except the fact the below the thumbnails i still can see the same articles in extended way and if i click on a thumbnailed title link, i can see the entire article below the thumbnails instead of going at the single article page.
is it possible to adjust these issue?
hope i've been clear.
13 years 1 month ago #1 by Giuseppe Scaramuzzi
Yes that because you've published Minifrontpage and assigned it to the Category Blog Layout menu item where those articles are belong. So every articles linked to that page (or menu item). It would be different if you assigned minifrontpage to your home page for instance.
If you will keep that minifrontpage to be displayed in your article category page then there's no way to hide it when you're in the article page, because article page will be based on it's coresponding category page (in term of their menu item id).
Hope it's clear for you now.
