Little problem with Carousel Banner
- Posted by Jose Luis Sierra (7) Offline
Hi there! first of all, thank you very much for your hard work an d willingness to giveus this great freebies and helping us to get them working on this forum.
I have this site, www.itservicesags.com/ and I used the carousel banner on the index, but for some reason I just don´t get, the module doesn´t work in th default mode, it never starts to roll the images... it works fine with the flexisel mode, but not in the other one. I used this very same module once, with the very same template in another site and there was working perfectly, but not any more.
Could you please help me with this? Thanks in advance!
13 years 1 month ago #1
by Jose Luis Sierra
Can you switch back to default mode so we can take a look at the problem?
13 years 1 month ago #2
Well....that works normal at my end now...no probelm at all, right?
13 years 1 month ago #4
- Posted by Eduardo (3) Offline
I have the same problem here. At the site www.espacocultural.com there is a carrousel banner in the center. I put in default to test and nothing changes. Can you help?
13 years 1 month ago #5
by Eduardo
What do you mean works fine at your end? I mean, i actually used the set up to start rolling the images automatically, but at my end, it doesn´t happend never. If you click on the arrows buttons, down at the right on the module, actually you can roll the images one by one, but doesn´t work automatically... am I being clear? I mean, animation should start rolling images as soon as the page loads, but it never happend.
Thank you!
13 years 1 month ago #6
by Jose Luis Sierra
Thank you!
