Carousel banner installation
- Posted by alberto (2) Offline
Hi! I am using Joomla 3.1.1 and downloaded and unzipped bannercarousel for J3.0. It doesn't work.
What can I do?
Thanks for your time!
13 years 1 month ago #1
by alberto
What can I do?
This is what I see:
Advertencia (Warning)
Advertencia: ¡Fallo al mover el archivo! (Fail in file moving)
JFolder: :files: La ruta no es una carpeta. (root is not a folder) Ruta (path): /home/vol11_3/eshost.es/eshos_13701653/htdocs/joomla/tmp/install_5242fd9649bdf
JFolder: :folder: La ruta no es una carpeta. Ruta: /home/vol11_3/eshost.es/eshos_13701653/htdocs/joomla/tmp/install_5242fd9649bdf
JFolder: :files: La ruta no es una carpeta. Ruta: /home/vol11_3/eshost.es/eshos_13701653/htdocs/joomla/tmp/install_5242fd9649bdf
JInstaller: :Instalar: No se ha podido encontrar el archivo XML de configuración de Joomla!
(Instal: Couldn't find XML file for Joomla Configuration)
13 years 1 month ago #2
by alberto
Hellp
First you need to unzip it first then find the correct installation file inside it.
13 years 1 month ago #3
