Xtypo Button not showing
- Posted by ivcc (2) Offline
I have purchased the xtypo-button and followed the installation instructions. But still do not see the button available under my TinyMCE editor.
Any ideas?
13 years 1 month ago #1
by ivcc
Any ideas?
Mmm well I post in other thread where you comment it.
Here it is I paste here
Hi ivcc
I thought the plugin has been updated so you can re-download it....
Meanwhile, can you edit this file
/plugins/editors-xtd/xtypo/xtypo.php at the following lines
notice my comment above, please add that button class line, save it and see if that works.
13 years 1 month ago #2
Hi ivcc
} else { // Joomla 3.1.x
$button->modal = true;
// add the following line below
$button->class = 'btn';
}notice my comment above, please add that button class line, save it and see if that works.
Thanks! That worked. Also, fwiw, I downloaded the program yesterday and it didn't have those changes in it... and I'm on Joomla! 3.0.x still I believe.
13 years 1 month ago #3
by ivcc
Yes that's correct and I've just updated the package 5 minutes ago...
13 years 1 month ago #4
