xtypo_button installation error
Hi, I bought the xtypo_button and install the following occurs:
JInstaller :: Install: Failed to find the configuration XML file.
I can not install it. Please help.
13 years 1 month ago #1 by xavier
You need to unzip it the package first and find the installation zip file inside it.
Have a try again
ok. perfect, solved.
thanks
13 years 1 month ago #3 by xavier
