I can't find an option in promospace for linking a module or a article?
I like it, but i miss a parameter in the promosettings for an image, article or module.
I use Joomla 3.01
Waiting for an answer.
Thanks Hubert
13 years 11 months ago #1 by Hermanns
There's a module parameter called Module Position to be filled to choose which module you want to be loaded by this PromoSpace module.
Create a Custom HTML type module if you don't have it yet for example then assign it to any module position then choose that position on your PromoSpace Module Position parameter. that's it.
Have a try...
13 years 11 months ago #2 by erwinschro
that is only the half solution. (Fyi i use Joomla 3.01 / gantry-framework and template)
  • If i postion the promospace to top and the custom modul to the same... I see nothing...all white.
  • If i postion the promospace to top and the custom modul to the showcase (over main)... I see the promospacer but i also see the custom modul in the showcase.
  • If i postion the promospace to top and the custom modul to the showcase but set it on hide .. I see the promospacer but no content from the custom modul?
regard Hubert
13 years 11 months ago #3 by Hermanns
The trick here is to position that Custom HTML type module (your promospace content) to a module position that your template doesn't have, a 'dummy' position we can call it (just create one 'promo' position by typing it in position parameter), so then it won't be loaded by the template but available for that specific menu item.
Don't forget to assign that custom module to a menu item where you want promospace to be displayed.
Hope that clear enough...
13 years 11 months ago #4 by erwinschro
Yes ist works.
Thanks.
HN
13 years 11 months ago #5 by Hermanns
I want to say, thank you. It works.
13 years 5 months ago #6 by sandy
