Problem in Cropping Image Related Items Extended
- Posted by Captain (20) Offline
Some pictures in my website aren't cropped well by Image Related Extended module.
You can see here
www.avmindirim.com/indirimler/10654-bils...uzde-50-indirim.html
13 years 1 month ago #1
by Captain
You can see here
Can you describe more what exactly this cropping issue is?
The problem I see in that page is not a cropping but a module position for this RelatedItems is not correctly placed. so the module looks like hidden from your content box. That's what I can see for now cause I don't see any cropping issue.
13 years 1 month ago #2
There was a div style problem i corrected it. I set thumbnails size 75x75 but related items extended module doesn't convert images to thumbnails. As you can see
How can i fix that?
And how can i regenerate thumbnails?
13 years 1 month ago #3
by Captain
How can i fix that?
Mmm...how did you manage to insert image on this article (the one that thumbnail works in RelatedItemsXtd module)?
Bilstore Haizran 2013 Yüzde 50'ye Varan İndirim Fırsatı
Can you try to do the same thing for these 2 articles?
Bilstoreout Tunel Mağazasında 27 Haziran 2013 Yüzde 80'e Varan İndirim Fırsatı Başladı
Bilstore'dan İstanbul Shopping Fest'e Özel %50'ye Varan İndirim Fırsatı
Let us know then...
13 years 1 month ago #4
Let us know then...
All of them is same
<p> <img alt="" src="images/stories/2013/06/bilstore-isf-2013.jpg" /></p>
13 years 1 month ago #5
by Captain
Mmm that's weird it looks like those 2 article image is hidden and RelatedItems Xtd can't see them.
Meanwhile can you change how you manage to insert those images? Rather than insert them inside the Text Editor, can you try to upload it from Images & Links tab at the right side of your Edit Article page. Insert them under Intro image field.
Hope that can temporarily fixed the cropping issue. Let us know then.
13 years 1 month ago #6
