Problem with Reponsive Banner
Dear Sir/Madam,
I have a problem with this module:
1 - even if it is marked "Open in New Window", my link opens in the same Window.
2 - I have a problem with a display of "navigation" Style 1 (next prev, play and stop are not displayed)
Elia
13 years 3 weeks ago #1 by Gazizova
Hello Elia
Can we see your case in a live URL?
13 years 3 weeks ago #2 by erwinschro
the-worlds-largest-cork-barrel.com/fr/barrique-geante
13 years 3 weeks ago #3 by Gazizova
Ok Elia
For the 1st issue, is it possible for you to overwrite this file
/modules/mod_responsivebannerslider/tmpl/default.php file with the one attached below?
For the 2nd issue, there's an override list item style from your template css. So you need to add the followong css inside this existing module css file
/modules/mod_responsivebannerslider/assets/sequence/themes/style1/css/style.css line 94-96
.rbs_controls li {
list-style: none !important;
/* add these class */
.box .rbs_controls li {
padding: 0;
position: absolute;
Let us know the result then....
13 years 3 weeks ago #4 by erwinschro
It works, thanks a lot!
13 years 3 weeks ago #5 by Gazizova
Finally, the first problem persists when I click on the title.
13 years 3 weeks ago #6 by Gazizova
