Pop Login Hangs
- Posted by miamiman (5) Offline
Still doing some testing... however I find that Pop Login hangs on latest install of Joomla and the module.
Any ideas?
13 years 2 weeks ago #1
by miamiman
Any ideas?
hi
can you explain more on this 'hang'? in what step that happen, is it in frontpage or backend admin?
13 years 2 weeks ago #2
Both on back-end (with Advanced Module Manager) and front-end... sometimes it stalls and nothing happens when I attempt to click-off...
I have installed jquery easy plug-in to see if there is a conflict with other plugins.
Is there a particular order for the plug-ins to have the module work reliably?
13 years 2 weeks ago #3
by miamiman
Mmm....it's hard to guess what could be the cause. Do you have a live url to check?
13 years 2 weeks ago #4
