Conflict with AddThis
First off, love your module! :D
It was working perfectly until I installed the AddThis plugin. I'm using the portfolio template and now nothing happens when you hover. If I change to another template the effects are distorted in other ways. What can I do to solve the conflict?
You can see the issue at:
www.sloris.com
Thanks for any help you can provide!
13 years 2 weeks ago #1 by Jesse Lambdin
Well if it works perfectly before you installed AddThis plugin, then the problem could be with the plugin....you can ask this issue to the dev of that plugin
13 years 2 weeks ago #2 by erwinschro
