MiniFrontPage - how to stop thumbs recreation every time when page reload
- Posted by karen (2) Offline
thanks for such a nice and free joomla extension.
Is there a way to stop regenerate the thumbnails after creation. is useful if you want to have better image like corner-cut or shadow , i create them with adobe and replece them in /images/minifp/ , but are deleted and recreated when i reload the site.
regards
Dan
13 years 2 weeks ago #1
by karen
regards
Dan
Hi Karen
Glad you like it...
MiniFP will generate thumbnail if you specified thumbnail width and height in it's parameter with this thumbnail dimension is smaller than the original images. If you specified them larger or at least same with their source image then MiniFP will not generate thumbnails.
Hope that clear enough...
13 years 2 weeks ago #2
Glad you like it...
thanks for your reply, but not helped me v much. , my image have fixed dimension at 600/400 px
i do some tests:
1. i setup the Thumbnail Image Width/High to 1200/800 higher then real size , the thumbs are regenerated when i reload the page
2. i setup Thumbnail Image Width/High to 600/400 px (actual size of pics), again the thumbs in /images/minifp/ are regenerated when i load the page
so every time the thumbs are recreated no matter what.
Karen
13 years 2 weeks ago #3
by karen
i do some tests:
Karen
Mmm....if that so then I was thought about another module that has such thumbnail processing...sorry if that's not work for you then.
13 years 1 week ago #4
