Mini k2 disable plugins
Hi, is there anyway to disable K2 and Joomla! content plugins in Mini k2 like in the k2 content module?
13 years 2 weeks ago #1 by menack
Yes that's possible.
Can you let us know your Joomla version so we can send you the right MiniK2 version to try?
13 years 2 weeks ago #2 by erwinschro
I'm using 2.5.14. Thank you.
13 years 2 weeks ago #3 by menack
Can you re-install MiniK2 module using this one attached?
Please go to it's module parameter, under Advanced Options tab at the right side, there's an option to disable K2 plugin.
Let us know if it works
13 years 2 weeks ago #4 by erwinschro
That worked thank you very much! :D
There was a conflict with Rich Snippets Vote plugin by deconf.
13 years 2 weeks ago #5 by menack
ok that's good to hear....
13 years 1 week ago #6 by erwinschro
