Problem with adjusting height and width in responsive banner slider.
I'm using the responsive banner slider for my website: p-j-p.nl/almere/ and I'm having difficulty to change to height and width of the banner.
I added the #responsivebannerslider {min-width:941px;} in the template.css and adjusted the height in the module, however the images stretches quite a lot and I want to have them set to the following parameters: width 941px and height 235px.
Hopefully you can help me out.
Thank you in advance.
PJPProjects
13 years 1 week ago #1 by Paul Peters
Hello Paul
This module will adjust it's width depends on the module wrapper width where it published, and the height will adjust accordingly. So, if you define the width your self then it will loose the responsive feature of it.
13 years 1 week ago #2 by erwinschro
Ok thank you, that's what I thought.
Now I have copied the banner into several positions and I want to set the one that is on the left to a fixed width and height. But how do I do that? If I change the template.css it'll affect all the banners right?
Ty
13 years 1 week ago #3 by Paul Peters
Sorry but you can't set their width and height individually cause it will affect all the banners, correct.
13 years 1 week ago #4 by erwinschro
