How to get rid of the navigation dot in Carosel?
I've found that it is calling a bullet file from the main template in the default carosel view, and I'd like to get rid of that... where do I change it in the mod? Its the dot that loads with every banner....
thanks for the great work guys, I was a Template Plazza customer all the way back in 2008, glad to see you're still around!
Jeff
13 years 1 week ago #1 by Jeff
can you provide a live URL so we can propose a solution?
13 years 1 week ago #2 by erwinschro
Sure... its in the upper right corner near the login button
siteground227.com/~thinkmag/praguepost.com/
13 years 1 week ago #3 by Jeff
Ok add this css class inside /modules/mod_carousel_banner/assets/css/jquery.jcarousel.css somewhere
.container-main .jcarousel-container ul li {
  background: none;
  list-style: none;
  margin-left: 0;
if that's still not working, try with this
  background: none !important;
  list-style: none !important;
  margin-left: 0 !important;
13 years 1 week ago #4 by erwinschro
that did it, (first one) thanks!!
13 years 1 week ago #5 by Jeff
ok that's good to hear...
13 years 1 week ago #6 by erwinschro
