Related Items Extendend not shown
- Posted by Alessandro Messineo (2) Offline
I'm trying to find the right way to see correctly the module. Below more informations:
1. Installed pkg and the plugin is correctly activated [attached n. 1]
2. For the module, title, position (content-top) and status (published) is correct [attached n. 2]
3. The module is assigned to a menu item that has article layout [attached n. 3/4]
4. All articles have the same meta keywords [attached n. 5]
Why I can't see the module? All configurations seem to be correct.
Thank you,
Alessandro Messineo
12 years 11 months ago #1
Thank you,
Alessandro Messineo
Solved. Load JQuery must be enabled in the settings of plugin. Please, write it in the documentations.
12 years 11 months ago #2
allright that's good to hear...
Enabling/disabling jQuery will depends solely on users setup whether their template already load it or not, whether they have another extension that already load it etc. So yes this is common problem and we're about to suggest this.
Again it will depends on user setup.
12 years 11 months ago #3
