Menu2panel + Virtuemart
I have a problem with the module = "menu2panel" and virtuemart, what happens is that when I walk into a virtuemart category menu, seen on tablet (Ipad) the menu stop working.
Is there any way to solve this problem.?
Regards,
12 years 11 months ago #1 by Andres Calvo
From what I can see, you're using jQuery library from Virtuemart on that page which has version a little bit old and I suspect that cause the problem.
Is it possible for you to de-activate jQuery from Virtuemart configuration then activate jQuery from MMenu module to test out?
12 years 11 months ago #2 by erwinschro
The solution works fine, now I have a new problem, what happens is that when I enter a product Virtuemart menu appears strangely, sending a picture so they can see what I mean.
Any help you can give me would be very important,
regards,
12 years 11 months ago #3 by Andres Calvo
Hi spacelab, Sorry for delay in responding. It's likely a javascript problem. Can you perform these solutions then let us know the result ? :
1. Switch the template into a default one (to check whether this is a template problem or somathing else)
2. Use jquery easy plugin (extensions.joomla.org/extensions/core-en...jquery-scripts/18327 to check whether it's a multiple jquery load problem)
12 years 11 months ago #4 by TemplatePlazza
