PHP Notice in Responsive Banner Slider
- Posted by capogr (3) Offline
Hi i am getting an error
PHP Notice: Undefined variable: i in .../public_html/modules/mod_responsivebannerslider/tmpl/default.php on line 223,
12 years 11 months ago #1
by capogr
<li <?php $i++; ?>>Please Log in or Create an account to join the conversation.
is it possible for you to edit that file /modules/mod_responsivebannerslider/tmpl/default.php? if possible then do the following
add declaration $i = 0
just before the foreach so it looks like this
then at line 223 edit it to
let us know the result while we're updating the downloadable file.
12 years 11 months ago #2
<?php $i = 0;
foreach() {
?>then at line 223 edit it to
<li><?php $i++; ?>let us know the result while we're updating the downloadable file.
PHP Parse error: syntax error, unexpected ')' in .../public_html/modules/mod_responsivebannerslider/tmpl/default.php on line 1
Sorry my PHP knowledge are limited
12 years 11 months ago #3
by capogr
Line 1? wew...
can you overwrite the existing file /modules/mod_responsivebannerslider/tmpl/default.php
using this one attached (unzip it first then upload to module folder above )
12 years 11 months ago #4
