XTypo used in an article with "readmore" tag
I'm experiencing an issue using XTypo in an article that has a "Read More" tag. I can use xtypo only if I agree to subdivide the text in two sections (before and after the "readmore" tag).
If I try to put xtypo tag only once, at the start and the end of my text, when the article is displayed in reduced format i can read the opening tag, however when i see the full text it appears formatted correctly.
any suggestions?
thank u in advance.
12 years 11 months ago #1 by Sestante2012
can you post a live URL where we can see the problem?
12 years 11 months ago #2 by erwinschro
What Joomla version you used? also do you used a commercial template? any specific content plugin that might cause the issue?
It shouldn't be needed to have an article with introtext and fulltext part for xtypo to work.
12 years 11 months ago #3 by erwinschro
Thank u for your reply.
Here is the link: www.studiobortolotto.it/servizi
As you can see, now, in the first article, the opening tag is visible. If you open the full content, you'll see that XTypo tag works great.
To answer your question, i'm using last Joomla! stable release and a free template.
I currently doesn't using any other content plugin.
Thank u for trying to help.
12 years 11 months ago #4 by Sestante2012
The problem is that article where you have xtypo_rounded tag gets cut at a number of characters and it looks like the closing xtypo_rounded tag get cut so that's why the plugin can't process the tag as there's no closing tag if it's displayed at your home page.
Hope that clear enough
12 years 11 months ago #5 by erwinschro
yes, all clear. thx.
12 years 11 months ago #6 by Sestante2012
