Joomla 3.2 and responsiv Banner slider
- Posted by Geert Koffeman (3) Offline
Same as post by "route2dmb" : After upgrade to Joomla 3.2 - responsive banner slider stopped working. In the module menu only 2 tabs are working. The rest is unresponsive.
12 years 11 months ago #1
by Geert Koffeman
can you set up a page with the module published so we can see it?
12 years 11 months ago #2
Negative. The banner/ slider does not work as mentioned before. Impossible to configure as none of the tabs in the module menu works
12 years 11 months ago #3
by Geert Koffeman
Can you turn o the Error Reporting and set it to maximum so we'd know if there's any error result from the Joomla upgrade?
12 years 11 months ago #4
- Posted by Frank Mayer (3) Offline
I stumbled on the same thing, however it's only a back-end design issue. The options are all there. Just need to scroll down.
12 years 11 months ago #5
by Frank Mayer
Thanks a lot. The tabs are just a sort of dummies. I never looked further down the page.
12 years 11 months ago #6
by Geert Koffeman
