Page Peel Banner
- Posted by Christian (2) Offline
This extension works perfectly on my home page, but if you go to a page other than the home one the module shows up in the bottom right corner as an image that isn't glowing and that you can not peel. Do you know why it is showing like this and is not in the right spot?
12 years 8 months ago #1
by Christian
can you post a live url where we can see the problem in your other page than homepage?
12 years 8 months ago #2
I've actually solved the problem. It was involving loading the jquery library.
Thanks!
12 years 8 months ago #3
by Christian
Thanks!
- Posted by gregor (7) Offline
Have you managed to test Page Peel on latest Joomla 3.2? It's not even showing
Thank you
12 years 7 months ago #5
by gregor
Thank you
- Posted by jcnr (1) Offline
Yes i have the exact same thing, does not work in joomla 3.2, what we need to do?
12 years 7 months ago #6
by jcnr
