article not appear in minifrontpage
mini ftontpage article not appear can you help me?
12 years 11 months ago #1 by ALEX
Have you re-check your articles with MiniFP parameters like category(s), dates - are your articles are still within the date range set etc...
12 years 11 months ago #2 by erwinschro
I had the same problem. The parameter, "Period of Novelty (Days)" actually determines the date range for articles included in the module. This seems like a needless setting. If your articlesa are all older than this period of novelty nothing shows.
I had assumed this would simply lable articles "New" for x number of days. The pop up help does not make it clear!
Change the setting for Period of Novelty (Days), actually, delete it and the default of 1200 will get filled in when you save. Unnecessary pain!
12 years 10 months ago #3 by John
