Add minimum amount of keyword matches: Related Items Extended
Hi guys,
I'm really digging your module, but I have a quite annoying problem, which is that it will almost inevitably show only the lastest posts, and not necessarily related posts. A solution for this is what the guys at FJ related Plus have done, which is to set a minimum amount of keyword matches to select the related articles, by doing this is much more likely you will get related articles in the module, and not only the latest ones.
Is there a way to do this already, and if not, any posibility of that you could implement it? It really is a very necessary feature if what you want is to make sure you're displaying related articles.
Thank you.
12 years 11 months ago #1 by Herman Haugland
First off thanks for your suggestion and we'll look into that possibilities
cheers
12 years 11 months ago #2 by erwinschro
