menu2panel not working
I bought the menu2panel and installed it on my website.
I can see the black block but nothing happens when I click on it.
When I select another template, everything is working fine, so I guess it has to do something with my own template, but couldn't figure it out.
Can you help me with this?
Thanks!
12 years 10 months ago #1 by geert
I guess that caused by 2 jquery library loaded. IS it possible for you to de-activate jQuery library from template parameter?
12 years 10 months ago #2 by erwinschro
Thanks for the answer. I disabled the jQuery from the template, but that won't help.
Can you login to the website and see what you can do?
I hope so!
12 years 10 months ago #3 by geert
Hi, from what I see there are two jquery libs loaded on your website. It looks like one loaded by your template and another one loaded by other part of your website. Please have alook on this screenshot : d.pr/i/OUfv
12 years 10 months ago #4 by TemplatePlazza
I disables one of the two query library's, but that won't made the menu working.
What else could be the problem?
Thanks!
12 years 10 months ago #5 by geert
Hi, I see your website loads these old javascripts :
<script src="/new/media/system/js/mootools-core.js" type="text/javascript"></script>
<script src="/new/media/system/js/core.js" type="text/javascript"></script>
<script src="/new/media/system/js/tabs-state.js" type="text/javascript"></script>
<script src="/new/media/system/js/caption.js" type="text/javascript"></script>
can you tell me what part of your website calls this?
12 years 10 months ago #6 by andy
