Responsive Banner Slider with Bootstrap 3
Hi there,
I wondered if anyone can help me... I have been trying to create a Joomla site using Bootstrap v3 to make it responsive. I also want to use your Responsive Banner Slider extension (which I have used several times before), however, I just can't get it to work on this site:
annpickardsugarcraft.com/theicingcentre/
You will see that the banner is loading but I suppose there is a jquery conflict or something - I'm afraid I'm no expert! I have tried setting the banner to not load jquery, to load it from Google and to load it from the plugin but none of the options seems to work.
Before I dismantle my site and make it a different way, do you have any ideas that I could try?
Many thanks
Leila
12 years 10 months ago #1 by Leila Hodgkins
First can you try to de-activate jQuery library loaded from your footer section (just before the closing body tag - I believe that coming from your template?) and keep it that way so I can take a look?
12 years 10 months ago #2 by erwinschro
Sure, it's done...
The banner is working now but, of course, now my bootstrap will not function properly.
12 years 10 months ago #3 by Leila Hodgkins
which part of bootstrap that will not function properly? is this bootstrap version really need jQuery v1.10.x? cause jQuery from the module is still use v1.8.3.
12 years 10 months ago #4 by erwinschro
Thanks for looking at the problem. I couldn't find any information about what version of jquery Bootstrap needs or whether it can be changed. So, I have started to rebuild my site using a responsive template which does work with your banner plugin.
Many thanks for your time and I do appreciate your help.
Leila
12 years 10 months ago #5 by Leila Hodgkins
