Carousel Banner Module in Joomla 2.5
- Posted by Steve (3) Offline
I have several issues at this URL:
www.karaokeacrossamerica.com/kaa-stuff/friends-of-kaa
If I use the default layout the slides never animate. They will scroll if I click the arrow, but never work on their own.
The module size settings do nothing in Flexisel mode.
If I use the Flexisel style the banners move, but I can't control the image size at all. They appear in the raw size of the image file even if I limit the size in the Joomla banner component itself.
I get the "Notice: Undefined variable: img_width in ......../modules/mod_carousel_banner/mod_carousel_banner.php on line 49" if I use Flexisel mode at all. If I use default mode I get no error.
There may be more once I can get some basic functionality.
Cool module and thanks for the help!
12 years 10 months ago #1
by Steve
Hi form your demo site, it looks like jQuery loads more than once. Please try to disable the jquery load from the carousel banner backend
12 years 10 months ago #2
I actually did that before I submitted this. I also tried loading jQuery from Google instead. Neither options resolved this.
I also tried the "patched" version that I found in another thread as an attempt to resolve the "mod_carousel_banner.php on line 49" error. It installed fine even though it said J3X, but I noticed I lost the option to even choose what jQuery options existed. I re-installed the original version.
Can you tell me what extension is loading the conflicting library? I checked to see what else may be doing this but didn't see any other optional modules/components loading. I admit I am not a serious coder though so I may miss it.
12 years 10 months ago #3
by Steve
