Carousel Banner with more than 5 banners
- Posted by jrthor2 (19) Offline
It seems that when I try to have 5 or more banners rotating, they show 2 stacked on top of each other, and rotate that way too, 2 stacked on top of each other. I am using the flexisel layout. Could anyone tell me how to allow 5 or more banners and still display correctly?
Thanks!
12 years 10 months ago #1
by jrthor2
Thanks!
Hi, Can you share your website URL so I can take a look?
12 years 10 months ago #2
Sorry, I thought I had provided it. It's www.zluth.org. You won't see the issue now though, as I can't leave the site up with the banners not working right, so right now I only have 4 banners rotating.
Thanks.
12 years 10 months ago #3
by jrthor2
Thanks.
Ah I see. I think it's probably something related to you banner width size.
12 years 10 months ago #4
but why would it work for 4 banners, but not more than that?
Thanks!
12 years 10 months ago #5
by jrthor2
Thanks!
Can you activate the fifth image for a seconds so i can see the problem?
12 years 10 months ago #6
