Does Related Items Extended work on Joomla 1.5????
Hi there. Does your Related Items Extended work on Joomla 1.5 and can thumnail size be customized? Need to know ASAP before i purchase. Thank you.
12 years 10 months ago #1 by Pat
Hi Pat, it supports thumbnail resizing but it dooesn't support Joomla 1.5
12 years 10 months ago #2 by TemplatePlazza
Oh really. That's too bad. Is there anything you can recommend for related articles thumbnails? Yours is great so it won't work eh?
12 years 10 months ago #3 by Pat
Joomla 1.5 is already reached its EOL so it won't be easy to find Joomla 1.5 extensions at the moment. Why don't you upgarde your website to joomla 2.5 or 3.x?
12 years 10 months ago #4 by TemplatePlazza
Will everything get thrown out of wack if i upgrade to 2.5?
12 years 10 months ago #5 by Pat
It depends on your website content and what extension you have on your website. You should check one by one all installed extensions whether they support J 2.5 or not.
If everything is ok, then make a BACKUP then use this extension to upgrade the joomla version :
extensions.joomla.org/extensions/migrati...omla-migration/11658
12 years 10 months ago #6 by TemplatePlazza
