carousel banner has dot in LH top corner of images
Love the module. nice and simple.
however, in my deployment, a dot is appearing in the top LH corner of each image, as if the module is using it as an edge marker for each image.
Why is this o?
12 years 8 months ago #1 by ajw
HI ajw,
Can you share your website URL so I can take a look?
12 years 8 months ago #2 by TemplatePlazza
I added it in the original submission but in case it didn't get stored here it is:
www.wphcfc.net.au
Can you hold off until after Christmas as we have a single image festive banner up at the moment which is';t using carousel. The important banner banner kicks in after new year.
Have a great festive season.
ajw
12 years 8 months ago #3 by ajw
hmm the website seems fine from here. can you elaborate the issue more? with a sceenshot maybe?
12 years 8 months ago #4 by TemplatePlazza
hi,
sorry for the delay in replying. Xmas and all that.
When you last visited the site, I had disabled carousel and used a simple image gallery for the festive message. hence why it all looked OK.
I have now re-enabled it and as you can see from the screenshot attached, the dots are easily seen. I have also done tests on disabling the background (the red section behind the carousel) to see what happens. The red dots are still there.
Eager to understand what the problem is.
thanks
12 years 8 months ago #5 by ajw
Hi, It's your template that added the dot images.
Please add this css code anywhere on your css file :
.nbs-flexisel-ul li {
	background-image:none!important;
12 years 8 months ago #6 by TemplatePlazza
