Mini Frontpage whole DIV clicable
- Posted by Mariusz (11) Offline
It's possible to make with Mini Frontpage whole place (not only title and image) clickable. I mean clickable DIV - .mfp-table-cell-inner.
Im using tabbed-slide-left-right layout.
Second question is about sef links. It's possible to made thats links but not to adding article or category to menu, not showing component/content/
12 years 10 months ago #1
by Mariusz
Hi marianok,
before the codein the files :
[root]/modules/mod_minifrontpage/themes/tabbed-slide-left-right/tmpl/bottom.php
[root]/modules/mod_minifrontpage/themes/tabbed-slide-left-right/tmpl/lastcell.php
[root]/modules/mod_minifrontpage/themes/tabbed-slide-left-right/tmpl/lastcolumn.php
(don't for get to add the closing </a> after the closing tag of <div class="mfp-table-cell-inner">
12 years 10 months ago #2
Yes you can try to addIt's possible to make with Mini Frontpage whole place (not only title and image) clickable. I mean clickable DIV - .mfp-table-cell-inner.
<a href="<?php echo $item->link; ?>"><div class="mfp-table-cell-inner">[root]/modules/mod_minifrontpage/themes/tabbed-slide-left-right/tmpl/bottom.php
Idon't understand what exactly you want here. can you elaborate it more?Second question is about sef links. It's possible to made thats links but not to adding article or category to menu, not showing component/content/
Thanks, I add style to DIV: <div class="mfp-table-cell-inner" style="display:block;cursor:pointer;"> and it works
Second question is about link. Now my links looks like domain.com/component/content/article/category-name/article-name
I would like it looks domain.com/category-name/article-name.
My each menu position is single article in there {loadposition categoryname} and for single page is another module with another category page.
My site has menu where each page is only for present articles from category.
When I dont get category to menu position links dont look fine and has "component/content/article"
There is any possibility to make SEF links?
12 years 10 months ago #3
by Mariusz
Hi Marianok, Sorry for delay in responding.
It's a joomla native behaviour. Maybe you can try this trick : try to create a hidden menu pointed to the category you want. Now the link should be changed
12 years 10 months ago #4
