Minifrontpage responsive
- Posted by jordi (7) Offline
I'm interesting in the minifrontpage module, but i have a responsive template. Is possible that de module will be responsive??
14 years 1 week ago #1
by jordi
- Posted by ronysyz (191) Offline
Can i see your live link, so i can give a precise trick
14 years 1 week ago #2
by ronysyz
Hi, thanks four reply !!!
I haven't the link, because i'm testing the web in a localhost.
I have the theme favourite of favtheme www.favthemes.com/themes.html
Thank you
14 years 1 week ago #3
by jordi
Thank you
Actually, you will need to add several css codes for example
so you will need to adjust your codes based on your template
Sorry if you need a precise trick, i just try at your live site , so just prepare it for us
Great Thanks
14 years 1 week ago #4
by ronysyz
@media screen and (min-width: 761px) and (max-width: 980px) {
.minifrontpage-default .mfp-table-cell-inner .mfp-img-right{
widht: YOURSIZEpx
.minifrontpage-default .mfp-table-cell-inner .mfp-img-left{
widht: YOURSIZEpx
@media screen and (min-width: 981px) and (max-width: 1200px) {
widht: YOURSIZEpx
widht: YOURSIZEpx
and ....so you will need to adjust your codes based on your template
Great Thanks
Thank you, when i up the web to a server, if i need help i reply in the forum, problably in 3 or 4 days.
Thank you very much
14 years 1 week ago #5
by jordi
Thank you very much
