mini fp thumbs
Mini fp is an exellent extension.
Here is my question : it is about creating thumbs from external images that has same names - mini FP doesn`t handle them correct - it takes first one and shows him repeatly. Any solution for this case ?
12 years 10 months ago #1 by joe
Hi mastergad, Unfortunately there is no easy solution for this case at the moment.
Minifp will create a new thumb image with name : xxx_thumb.jpg inside the folder [root]images/minifp.
If the thumb image exists then minifp will use the existed one. That's why you have to give a different name for every image.
12 years 10 months ago #2 by TemplatePlazza
yes - that is exactly what happens in my site. But this could be corrected - before a new thumb is created, mini fp has to check if that name exist and if yes - than a simple number has to be append at the end of the old file name ( xxx_thumb.jpg - > xxx_thumb_1.jpg -> xxx_thumb_2.jpg and so on ) .
I need this modification for my site, and i dont expect to be free of charge.
12 years 10 months ago #3 by joe
