I need help uploading banner to website
- Posted by odonis (3) Offline
responsive banner slider: cannot be upload to my website, please help
12 years 9 months ago #1
by odonis
Hi, Can you tell me what exactly the problem is? Are you unable to upload the resposive banner module itself or uploading banner image?
12 years 9 months ago #2
When I upload the banner to joomla it says successful but then I cannot find it in joomla. I think the server think I using it for another website since I upgrade from joomla 3.1 to 3.2.
12 years 9 months ago #3
by odonis
Hi, I have entered your website but it looks like responsive banner slider is not yet installed. Are you sure you have installed it?
12 years 9 months ago #4
Responsive Banner Slider
I just purchased the Responsive Banner Slider again just in case something is wrong with the first one but the problem still remain, I did all the steps to up load the banner but when I look in my joomla folders the banner is not there, I use joomla 3.2.1.
Please help
12 years 9 months ago #5
by odonis
Please help
Hi Odonisr,
Sorry, I wasn't aware you're commenting my reply. Next time please do not comment on a reply because this will not send me notification email. Use the reply (Submit Your Response) instead.
Are you able to install other extension? If you're unable too then it looks like there something wrong with your joomla installation
12 years 9 months ago #6
I couldn't install in, joomla doesn't allow me to do so. I did it many times, I got the success installation message from joomla but when I look at installtion folder the banner is not in there.
