Images in Latestnews+ not allways showed.
We are using Latestnews+ on www.hongarijevandaag.nl.
Not allways are the images showed on the frontpage, under 'Nieuws'.
What can be the problem?
Jan
12 years 9 months ago #1 by Jan van Kuijk
Strange, Did you upload/insert all image with the same method?
12 years 9 months ago #2 by TemplatePlazza
Yes. It's the first image in a Joomla content item.
Here an example:
www.hongarijevandaag.nl/portal2/cultuur-...tragedie-van-de-mens
The code
<img src="www.hongarijevandaag.nl/portal2/images/2012foto/jmmsz1kl.jpg" width="120" height="83" alt="jmmsz1kl" style="margin: 5px; float: left;" />Maandag 30 december 2013 - Het draaiboek lag in 1983 al klaar, maar pas in 2011 kwam de film 'Az ember tragédiája - De tragedie van de mens' van regisseur, graficus en illustrator Marcell Jankovics uit in de Hongaarse bioscopen. Deze prachtige animatiefilm draait op 19 januari in de Hongaarse Salon te Amsterdam.
Strange: The newest article is doing ok:
www.hongarijevandaag.nl/portal2/overigen...t-mangalica-festival
12 years 9 months ago #3 by Jan van Kuijk
Hmm so only old contents were affected? The new ones will be just fine? Can you try to add more article to confirm this?
12 years 9 months ago #4 by TemplatePlazza
In a single article it looks normal: www.hongarijevandaag.nl/portal2/overigen...furmint-februar-2014
But in blog layout not:
www.hongarijevandaag.nl/portal2/overigen...everage-mainmenu-206
Even all picture a showed in 100 x 100 px. In the module the height is 100%.
Jan
12 years 9 months ago #5 by Jan van Kuijk
Hi I don't understand what's exactly the problem. I didn't see the module published on those pages.
Can you please elaborate more on it
12 years 9 months ago #6 by TemplatePlazza
