Carousel Banner is not working
- Posted by Franklin Vandeputte (1) Offline
I installed Carousel Banner on our website.
I have put the banners on autoplay, but when I publish the modules and take a look at the front side, the first banner stays stationaruy on the screen.
What did I do wrong?
If I want to change to flexisel, nothing at all shows.
12 years 9 months ago #1
- Posted by Franklin vANDEPUTTE (1) Offline
My URL is www.kfcaalbekesport.be
I also see that on both sides of the logos a margin is cut. As a result of that the logos are not complete.
What can be the reson for that?
12 years 9 months ago #3
Hi, it because of your template css. Try to add this code anywhere on your css file :
12 years 9 months ago #4
.jcarousel-item {padding:0!important; background:none;
